Rear discs done, does it look ok? *pics*
Discussion in 'The Garage' started by divorced, Oct 4, 2004.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I just got done with the rear discs on my 14 bolt. (Thanks cybrfire for the cool brackets /forums/images/graemlins/waytogo.gif) I couldn't find a lot of info on how to run the lines. I used hoses for a 1979 Chevette and then hard line to the center. I cut the hard lines to the correct length and used a double flare tool that I bought at Napa. Does anything look unsafe or disasterous? Also, the springs are 5.5" lift springs, what's the deal with the curved overload? it doesn't sit very well on the block, it only touches near the center.
    Bonus pic, critique(sp?) my welds. (It was done with a stick welder)
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Looks good, but I would try to raise those rubber lines up some so they don't get caught on anything. Nice weld for using a stick. /forums/images/graemlins/thumb.gif
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Looks ok to me apart from that flexi hose hanging down so far just waiting to snag a rock. As for the springs....weird, looks like they'll be prone to easy axle wrap.
  4. divorced
    Jul 20, 2004
    5,115
    Yes, they do wrap easily. The truck had factory 3/4 ton springs with an add-a-leaf and a 4" block and axle wrap wasn't a problem. I think I will remove the 2" block and buy some 1" zero rates.
    The hose hangs down the the bottom of the axle tube, but no farther. There are no rocks around here, just a bunch of mud. I may see what can be done to raise it up some though.
  5. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    You could probably tie the hoses up to the ubolts with some zip ties. Looks great. /forums/images/graemlins/waytogo.gif
  6. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Looks very professional! I wish I could weld as good as you can!
  7. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Did you go with the e-brake (caddy calipers) or not?
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'd either dump the overloads or flop them upside down.
    If you flop them you can drill the rear end of each and bolt on a leaf keeper that rises above the main leaf by a little. That way when the spring tries to wrap the keeper's cross bar will contact the main leaf and make the overload act as a traction bar. Lest you think I'm smart or something equally terrible, this is what yoter did on my '84 4wd and it works well.
  9. divorced
    Jul 20, 2004
    5,115
    Thanks, I can weld fairly well with a stick, but not at all with a wire feed /forums/images/graemlins/dunno.gif
  10. divorced
    Jul 20, 2004
    5,115
    No, I went with the front calipers. I have read opinions both ways on the caddy calipers, some say they work well and others say they don't. My cables were also messed up so I didn't worry about the parking brake.
  11. divorced
    Jul 20, 2004
    5,115
    I think I understand what you are saying. Flip the overload, leave it on the bottom, and a bracket that goes from it to the top of the main leaf? Kind of like the bolt-on overload leafs?
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Once you get the hang of it, it's much easier.
  13. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Yes, leave the overload where it is, just flip it 180* so it arcs down instead of up. That alone will be a significant improvement in ride quality.
    Some leaf keepers have a bolt and a sleave across their tops, rather than being pinched down over the top leaf. If you do this on the rear of the overload leaves and leave some space btwn the sleave and the main leaf, then when the spring tries to wrap the rear of the overload will go down and pull the sleave into contact with the main leaf. The only other time the sleave will come in contact with the main leaf is when you hang that tire in the air.
    With the amount of arc that overload has in it you may want to start out with a Suburban overload as they are flatter.
