rear discs on 90 k5
Discussion in 'The Garage' started by browningejm, Jun 9, 2005.
  1. browningejm
    browningejm Registered Member
    Mar 23, 2005
    47
    LONG ISLAND, N.Y.
    I have a 12 bolt from a 75 k5 w/ rear disc brakes. will it work in my 90 with the existing master cyl. and what effect will it have on the abs? TIA, ERIK
  2. browningejm
    Mar 23, 2005
    47
    LONG ISLAND, N.Y.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    If you have ABS all the way around, it will mess with your computer. Not sure whtat to tell you about that. If the ABS is only on the front, then it won't affect it at all. AFA the MC goes, it should work ok. You might want to consider stepping up to a 3/4 ton MC if you experience a soft pedal after the swap.
    Also, if you do it, make sure you get ALL the air out. I thought I had all of the air out of mine and I was wrong. Poor lady at the stop light musta wet her pants when she saw me rollin gup on her. I got lucky. I stopped approx 1" away from her rear bumper. Scared the hell out'a me!
    I run rear discs on my '74 using the stock MC and I have no issues. I didn't need a prop. valve either. You might try contacting Wilwood and asking them some questions. Pretend you are interested in one of thier brake systems and they will spill their guts to you. Ask me how I know :deal: :whistle:
