rear discs with 15" rims? doable?
Discussion in 'The Garage' started by sled_dog, Oct 28, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    rear discs with 15\" rims? doable?
    Ok I am probably buying a parts c20, and I'm thinking pull the calipers for rear disc on the K5. Drums and brake assembly I have are worn out and someday I want to go disc anyway. Could I fit 15s on with a disced rear 14 bolt?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: rear discs with 15\" rims? doable?
    Mine fit without any problems. The brakes are set much farther inboard with the rear setup. /forums/images/graemlins/cool.gif
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Worked for me, check out my webshots.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Mine fit fine with 4.25" of back spacing. /forums/images/graemlins/thumb.gif
  5. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Mine fit great too........ The 14 bolt has thicker spacing between the rotors & lug studs.
  6. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i had to grind mine just a little. much less than i had to grind the front. i have 3.5" of backspacing and caddie calipers.
  7. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    i had to grind one a little and the other a good bit but runnign 15's without a problem...
  8. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    yes it can work, chevy4wd has it..
  9. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Mine fit with a little grinding on the caliper. Mainly just to clean the casting marks off. Not sure on the backspacing though.
