Rear disk brake praportioning valve Q's
Discussion in 'The Garage' started by Skyetone, Apr 24, 2002.
  1. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    Rear disk brake praportioning valve Q\'s
    I have a few Q's in relation to my other thread. Can you use the stock booster and or proportioning valve with rear disk breaks? I am under the impression with power breaks and the rear calipers being 1/2 ton that it is all ok? I have the setup already but was unsure if the rest of the componetry was up to snuff.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: Rear disk brake praportioning valve Q\'s
    Most people on this board have good luck w/ the stock master, prop valve, and booster (as long as your truck is 71 or newer...meaning not 4wheel drum). I am going to try taking out the prop part of the prop valve (leaving just the idiot light switch) and install a wilwood adjustable prop valve (even though it works fine the way it is...I just can't leave well enough alone).
  3. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    thanx for the info. If my truck is 4w drums then is it hard to change to a newer portioning valve?
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you are going to change to a different prop valve you might want to go w/ one from a car w/ 4 wheel disc. Check out "Steve_Chin"'s website. He has alot of info on doing a rear disc swap into a 1st gen. He normally posts on the 1st gen board only.
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  6. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
    Where exactly is the proportional valve on my 71 blazer?
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is mounted right next to the master cylinder...you can't miss it.
  8. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    thanx for the "dummie page" I'll go from there. It isn't necesarty to change out though is it?
  9. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What year is your truck? I don't know how to tell if it has the drum MC and prop. valve...I have never seen one. If it does have the drum stuff I would swap it out, and if you are going to swap it out why not get stuff made for 4 wheel disc?
  10. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    It is a 70 but it has been skabber together. So no telling whats what. The body is original /forums/images/icons/laugh.gif thats about it.
