Rear Disk Brake Question
Discussion in 'The Garage' started by blazin topless 75, Mar 22, 2004.
  1. blazin topless 75
    blazin topless 75 Registered Member
    Feb 5, 2004
    47
    Connecticut
    Is it possible to use calipers from a newer vehicle? I was eyeing the calipers from my wife's TrailBlazer and got to thinking that if I could fab the mounts for it, it might work and it would be easier to fit the E-Brake hardware due to availability...what are your thoughts?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    With a Torch and a welder. ANYTHING will fit. If you can get one off and compare it's mounting to the 10bolt front calipers we would have a better clue. But i don't know of anybody who has a "kit" to put them on. Fabrication will be needed.
  3. blazin topless 75
    Feb 5, 2004
    47
    Connecticut
    Are the parts readily available for E-brake installation for the Caddy calipers? I've read the install info on this site and it seems that the hardest part is finding donor e-brake parts to add to the install. Is there anyone out there that sells the complete kit including the e-brake parts?
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I got my bracket and hose kit from Azkickin , got my caddy calipers from Car-parts and I'm working on getting ebrake cables, haven't figured that one out yet as I had a fellow member rebuild my calipers for me and haven't gotten them back yet but are suppose to be here this week /forums/images/graemlins/thumb.gif
  5. blazin topless 75
    Feb 5, 2004
    47
    Connecticut
    Did your calipers come with the E-brake arms?
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes they did, came with the arms and springs....they even sent me the used pads that were on them and the caliper mounting bolts /forums/images/graemlins/thumb.gif
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Like posted above, anything will work with enough fabrication.
    But here are things to be aware of:
    1) Is the e-brake actually through the caliper? On a lot of newer trucks, there is actually a machined surface on the inside of the rotor where a drum-brake emergency brake makes contact. The e-brake doesn't do anything to the caliper.
    2) How big does the caliper open? If the rotors on a trailblazer (or whatever the donor vehicle is) are much thinner than a Chevy 3/4 ton 8 lug rotor, you're going to have fitment issues.
    3) Dang, I thought I had another one, but I can't think of it now. /forums/images/graemlins/smirk.gif
  8. heavy4x4
    Aug 28, 2002
    3,270
    How much did they cost, if you don't mind telling?
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    The ones I found cost me $35 + shipping for the pair /forums/images/graemlins/thumb.gif
