rear disk brake question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Casey 86K5, Nov 7, 2000.
  1. Casey 86K5
    Casey 86K5 1/2 ton status
    119
    Brownsburg, Indiana
    I have decided to convert my 14 bolt FF to rear disk brakes. I am going to go with the newer TSM kit that uses the 3/4 ton Chevy rotors. My question is about the e-brake cables. Will I have to buy new cables or will my stock cables work with the Eldorado calipers? any help would be greatly appreciated
    thanks
    Casey 86K5
    http://86blazer.coloradok5.com
  2. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    You may want to do a search on this. There have been a couple of posts discussing ebrakes with those cal's. If I remember right the answer is no. And you will need to get the ebrake arms for the calipers at a wrecking yard. I don't think you can get them at the store anymore. Call your local auto parts store and see if they carry the arms. Good luck,hope this helps!
