rear disk brake ?'s
Discussion in 'The Garage' started by screamer*145, Oct 3, 2006.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    I have the disk setup done on my 14bff and the rear brake are hardly working. I am contimplating to just run direct pressure to the front and to the rear with a adjustiable proprtioning valve in the rear. Will there be any problems with this setup?. Also has anyone tried using this yet?
    http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10001&catalogId=10002&catalogIdentifier=Jegs_Direct&categoryId=115435&parentCategoryId=10165
    Any advice is welcome!
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    you need to bleeeed bleed bleed........then do it all again.
    the pressure to activate your drums should be locking up your disks, the proportioning valve is to dial down rear line pressure.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Ditto.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    X2
    Search the power bleeder project (lawn sprayer) around here somewhere. Should help with that.
