Rear disk brakes for you 10-bolt from the GM dealer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blue85, May 31, 2001.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    I don't know if anyone else has been noticing this, but the brand new GM trucks with rear 10-bolts all seem to have rear disk brakes. These have the standard GM 6-lug pattern. Has anyone checked to see if these rotors, brackets and calipers can be put onto the ends of an older 10-bolt axle? They must have some provision for a parking brake, too. So what we need to know is:
    -Does the new 10-bolt have the same 4-bolt pattern that holds the brake on?
    -Does the backing plate/bracket provide the right spacing on an old 10-bolt?
    -How does the parking brake connect?
    -How much would all of the parts cost?
    Myself, I am planning a disk brake upgrade for a S/F 14B, so I won't worry about this, but I thought that it was an idea that some of you would be interested in.
    Shoot, for all I know, these brakes would fit on a 12 Bolt...
    <font color=green>Why does everyone worry about my gas mileage, but not think twice about an Excursion owner?</font color=green>
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Interesting thought. I've got to run to the Chevrolet dealer later, and I'll throttle the parts guy for information.
    I'm not creative enough to comeup with a new signature [​IMG]
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Funny you should mention this... I saw a new-style Chevy pickup on a flatbed the other day with the frontend smashed real bad. These trucks should start turning up in the junkyards soon.
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
    <A target="_blank" HREF=http://www.jarheadsk5.coloradok5.com>http://www.jarheadsk5.coloradok5.com</A>
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    According to the parts idiot, it should work, but we'd have to change the brake lines to metric, and adapt the parking brake cables from a Silverado. Other than that, he says it should be a bolt on affair. (Needless to say, it probably won't be)
  5. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Not sure if it would work, but I do know that my buddy has a 2001 Z71 and we tried to fit my 15" aluminum rims on it. They will not clear the calipers, you would have to use a 16" or 16.5" rim. Cool Idea though
    BlazerBoy
    http://generalblueballs.coloradok5.com
  6. Blue85
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    That was a 6-lug setup then?
    I actually looked for some of these parts and came up with about $100 each for the calipers and around $50 each for the rotors. $100 is actually less than a Caddy caliper unless you have some old ones for cores.
    <font color=green>Does a Dyslexic Insomniac Athiest lay awake at night wondering if there's really a Dog?</font color=green>
