rear disk brakes
Discussion in 'The Garage' started by snakebat883, Jul 4, 2005.
  1. snakebat883
    snakebat883 Newbie
    Jul 4, 2005
    3
    louisiana
    is there a company who sells an aftermarket rear disk brake setup for a '85 blazer
  2. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
  3. dremu
    Feb 27, 2000
    15,954
    444
    East of San Francisco
    Lots. Do a Search here, or you can even DIY with junkyard bits:
    http://www.wrath.com/4x4/tenboltreardiscbrakes.htm
    Mind you, be sure you want to do this, as it's $$ and some time (and you have to pull the shafts on semifloats like your stock 10-bolt, grr) ... if you're thinking of upgrading, do the axle upgrade now, as the disc upgrade won't go onto a 14 bolt rear.
    I still have all the stuff to do a parking-brake rear on a 12-bolt that I've never installed, as I seem to have put a 14 BFF (also disc) on the '74 I was gonna use it on.
    -- A
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Someday I'll update that article. It was never meant to be permanent. I never even proofread it. After doing 5-6 of these swaps on 10 bolts and 12 bolts I have some new info to put on it.
