Rear Disk brakes
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by txgp17, Oct 17, 2001.
  1. txgp17
    txgp17 Newbie
    Oct 17, 2001
    Greensboro, NC
    Hi guys,
    New to the forum, just bought my 1972 K-5 Blazer, CST package, 350 engine, 350 auto. I'm not at all new to GM 4x4's, I know the 73-87's in and out, and I own a 99' too. But this is my first 69-72 model. I know one of the first mods I would like to get is a rear disk brake conversion kit. Any suggestions?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    hey guys we got another one. congragulations and welcome aboard to the most addicting site :-) sounds like a sweet ride. some suggestions fill out your profile become a member and post some pics. you wont regret it. Steve Chin has a write up on rear disk brake conversion.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    TSM seems to be the most common kit to do this....ORU makes one also but for some reason it's WAY more expensive than TSMs. I don't have the URLs for these, but you can easily find both in any 4WD mag, or someone here may throw the link at you!! [​IMG]
    I know a lot of guys have done "homebuilt" disc brake conversions too with Eldorado calipers, and some other off the shelf parts. Check the archives, and I'm sure you find more than you ever wanted to know. This topic has been discussed many times...
    Welcome to the group!
    -Greg72
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I have a TSM kit on my 14 bolt full float. PM me if you have any questions
  5. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    I used the kit from TSM as well, It is fairly inexpensive and easy to install. Look in the back of a 4x4 mag for their number.
    Someone mentioned Steve Chin's write up as well, it is very helpful. Good luck.
    Jeff
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    My write-up centers on a TSM kit, but it would be similar for the Warn kit. I haven't seen the ORU kit. The thing I don't like about both the Warn and TSM kits is that they are both designed to work with GM mid-size front calipers and the '79-'85 Eldorado rear calipers just so happen to fit into the brackets, but they're tipped over so that it's impossible to properly bleed them when they're mounted to the brackets. I'm going to home-brew some brackets for my Blazer at some point in time and correct that.
