Rear Disk break question
Discussion in 'The Garage' started by AnthonyG, May 14, 2003.
  1. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I know there was a post asking this same question A while back bus i couldn't find it in the search.
    I just got my disk breaks on the rear tonight and bled them all realy good. Now when i drive it, The pedel goes realy far down and the breaks realy suck. My question is Do i just have to gut the porprotioning valve to make the rears work better or what. I was under the impression that the reason for gutting the valve was because the rears were locking up but I don't even have enough stopping power in the back to stop the wheels with the back end off the ground. I know that this has been ansered a million times but if you could anser it one more time or gimmy a link to the answer I would be happy
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Your asking the very same question i did about a month ago. I had the same problem. I used a master cyclinder off a 78 vette with four wheel disc. Hugh differnce. Bolted on with no adapters for lines. Did however cost 80 bucks for a new one. I think you can get a rebuilt for like 30. Try that then get them powerbled. Im much more impressed now. If you have any more questions PM me.
  3. dyeager535
    26,979
    How did the '78 one bolt up with no mods? The 4 wheel disc 'vette masters I've seen (like '68) use the same size fitting front and rear, all disk/drum masters I've seen (truck or car) all use smaller rear fittings/lines, since the drilled orifice in the master cylinder for front/rear brakes are different sizes.
    If the '78 vette uses the same size fittings as the trucks, that would be an awesome swap.
  4. white-rhyno
    Jan 27, 2002
    942
    Im almost positive it was a 78. Ill get a PN number from napa for you later today. I have a bad habit of not keeping recipts. Would it matter that im working with a 76 k5?? Maby thats why i didnt need any fittings? Or maby i just got lucky.
  5. dyeager535
    26,979
    I checked on my dads '74, same deal.
    It could be that the Corvette master later on had different sizes lines like the trucks, I was looking at one 10 years older.
    Took a cursory glance at all the GM cars in the 'yard I looked at, all the master cylinders for disk/drum cars had different size fittings.
  6. white-rhyno
    Jan 27, 2002
    942
    Napa PN# for the MC #39052. Hope that helps
