Rear disk what else do I need? New question on page 5
Discussion in 'The Garage' started by Chrisblazzer89, Apr 24, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok I want to do a disk brake conversion on my 14BFF and this is what I have come up with is it all I need what am I missing?
    [FONT=Verdana, Arial, Helvetica, sans-serif]DIY4X Disc conversion kit $70.00
    Autozone 1987 3/4 ton front brake rotors x
    [/FONT] 2 = $49.88
    [FONT=Verdana, Arial, Helvetica, sans-serif]Autozone 1987 3/4 ton front brake calipers, pins, pads x 2 = $56.95 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif](after cores, yes I have cores)
    [/FONT]
    [/FONT]
  2. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok so far its $149.86 I know I'm missing the brake hoses and shipping for the brackets but what else am I missing?[/FONT]
  3. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    does your state require an ebrake?
    also toss in cost of fluids, and maybe a proportioning valve to adjust the brakes afterwards. Heard that makes the brakes alot easier to adjust post swap.
    Remington
  4. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    My state does require an E-brake but around here the Inspection places get paid off if you dont have one :deal: :D I know this because this is what my mom does:eek1::haha:
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    sure is going to be hard to stop without pads.:doah: :D
  6. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    :haha: I was just about to say that!
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    New flex lines to the rear calipers
    Replace the hardline with shorter pieces...no sense in having a loop from using the current lines
    Caliper pins
    Brake Pads
    Fluid
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    buy loaded calipers, should come with pads an hardware...
  9. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    may also need rear axle seals... depending on age and condition of current ones. But fortunately its cheap, like $4 a side
  10. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    I just rec'd a set of brackets from Dan at Ruff Stuff Specialties.
    Top notch parts & he offers a CK5 discount on them (look in the vendors section)
    I liked the fact that there is no need for the spacer & longer bolts .
    Just another option for you to look at
  11. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Man I almost fell ouy my seat when I read that
  12. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Do they sell them at autozone, advance or napa?
  13. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    About replacing the hard lin can't I just cut them shorter and flare them and then use the lil conector for hard to soft line? like there is in the front?
  14. mechted
    Oct 19, 2003
    765
    Granbury, TX
    yep
  15. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    [/FONT] 2 = $49.88
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif][/FONT]
  16. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    [FONT=Verdana, Arial, Helvetica, sans-serif]Brake hoses x 2 = $37.98
    Brake fluid x 3 = $11.88
    [/FONT]
    so far [FONT=Verdana, Arial, Helvetica, sans-serif]$226.69[/FONT]
  17. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Whats the lil connctor thing called? Or is it built in to the end of the hose?
  18. mechted
    Oct 19, 2003
    765
    Granbury, TX
    Its a brake line inverted flare nut... you can just use the ones that are on your lines right now, but if you want to replace:
    Dorman P/N: 321413.1 3/16" Steel Nut
    Any autoparts store should be able to get it for you... i think they are only a couple bucks each\
  19. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    My rear hard lines are new like mabe 1 month old so i will re use mine
  20. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok so everyone with 14BFF who have disk am I all set?
