Rear disks with emergency brake rotors
Discussion in 'The Garage' started by MaxCrack, Feb 13, 2006.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Does any know of a rotor with a drum built in for the e-brake that will work on a 14 bolt?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    There is a company out there, I was doing a random search last night on a different but similar subject and stumbled across that. Do a net search and see what comes up.
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  4. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    no he wants rear disks with the e brake on the inside of the rotor like alot on newer trucks had where the shoes expand and hold the rotor like a "mini drum" setup
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    They come that way from the factory in some newer Chevy trucks. The drum is the inside part of the rotor.
  6. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Ah, like a C3 Vette.
  7. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    I run mine off the t-case - Jess
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Not everyone can do that :( And some (but not mine) states don't allow that for inspection.
  9. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    My uncle has got a 14FF laying around out of a 2004 chevy 2500HD. It has dual piston calipers, and Internal parking brake, and I tell you... it is one nice axle. Id hate to see what he wants for it, prolly around 800-1000.
    As far a conversions, I say find one of these axles, butother than that, I dont know.
  10. wkbrdrob
    wkbrdrob Registered Member
    Feb 7, 2006
    63
    Salem, OR
    I hear that 76-78 Elderado rear calipers have a e-brake in them, but I'm not exactly sure how they work out. It's on my list of things to do......:D
  11. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    yes, but he wanting disks with a internal drum type e-brake ike the ones that come on all the new vehicles with rear discs.
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I think there is a difference in the backing plate surface that will not allow it to be bolted to a drum type housing even if you did a complete changeout. It has been discussed on here previously. The only way I can think of doing it is to swap a 14FF with factory discs on from a totalled truck.
    Ira
  13. kd7kmp
    kd7kmp Registered Member
    Jun 2, 2004
    99
    Springivlle, Utah
    They're called Drum-In-Hat rotors. They should be on most, if not all, GMC trucks that came with rear disk brakes from the factory starting in the early '90's. They will not simply bolt up as the rotor is MUCH different than the rotor used on 14 bolt swaps.
  14. pumpkin
    pumpkin Registered Member
    Nov 5, 2004
    14
    Got them on my 72 Blazer, work fine. I went for rear disc, cause the mud would eat the rear shoes in a couple of weeks. With the park brake being drum on a rear disc setup, you would be in fore a lot more maintainance work to keep te park brake alive.
  15. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Interesting.... how do they handle OE applications with this setup? Or a trans-mounted brake?
    For the original question... I've seen of a couple of successful swaps where the whole brake setup is stripped from a donor axle - and then the backing plate flange on the recepient axle is moved to suit.
    EDIT: Ford E350/450 are another good donor with the correct bolt pattern.
  16. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I would have to see the specific state's requirements to know for sure, but I can't imagine that not being legal. My '71 Toyota FJ-40 has the same basic setup (except drum instead of disc) that is all factory.
