REAR DOUBLE SHACKLE IDEA?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLUESMAN, Dec 18, 2001.
  1. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Has anyone thought of or done a double shackle on the rear?I was thinking of this this morning and I don't see any reason not to try it.I know I will not achieve any lift from it, but the it would provide more travel in the springs.I just took two of the stock shackles and looked at them and it looks very feasible.The ride height should be the same since the two shackles will fold together and straighten out when fully flexed.Comments???
  2. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Or how about using a Bell Tech lowering shackle with the flip?
    Rob
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  3. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    I thought about it. And I talked to Steve At ORD and he wrote me back and explained that to find the correct pionion angle and have tracktion bars set up and all that good jaz. would not be worht it. He suggested to go with longer then stock springs and have a heep style shackel. Infact that is what Steve at ORD did.
    Just my two cents... Later KEN
    DANGIT it's not a bronco!
    &lt;a target=&amp;quot;_blank&amp;quot; href=http://community.webshots.com/user/kensk5&gt;My Picts&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by DuneRunner on 12/18/01 02:08 PM.</FONT></P>
  4. BLUESMAN
    Oct 3, 2001
    951
    Yeah I looked at "Desert Steel" longer shackles, but I don't want the lift.My thinking was that it would be a far cheaper version of the "revolver" type shackle.I'm already going to install the 56" long springs, just looking for the max. travel that I can get.Oh I'm also installing the frt. spring mount for the "shackle flip".I thought I saw someone did something similiar to this in the member's rides.
  5. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    I have revolvers on my rig and they work fine, but that is after modifiying them to not open when on road by use of a disconnect system for when off road. I think there is a guy on this sight that has a better setup. Marv Springer, and I think he could make and sell one. I believe FrizzleFry is also using Marv's setup.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    The Gen: I have a set of revolvers that I am gonne install when I do my shack flip. What exactly did you rig up to keep them from opening on-road? Have any pics? I wanna stay safe on-road. ;) Thanks in advance!
    Jason
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  7. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I have wheeled with FRIZZ once before he had the Marv Springer set up. Check out his members pics...Talk about flexx
    Blues Let us know how things turn out...
    Later KEN
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    if you are going for max flex go for the 63" rear springs. even Taco's are running them with extensive mods.
    -zakk
    '77 1-Ton K5
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  9. BLUESMAN
    Oct 3, 2001
    951
    I don't think that I would have the frame for 63's, besides I already have the 56's.The mounts for the rear hangers are at the very front of the rear bumber brackets.Hopefully by next week(???), I'll have it all installed.Now to order another set of urethane bushings!!!Does this ever end??I still have to install the 3/4 diffs!!!
  10. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    check with Marv...he's gota cool setup. marv_springer@hotmail.com
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  11. Parf
    Parf Registered Member
    Nov 16, 2001
    81
    Golden, Colorado
    Are you thinking of something like the Hypershackles available for Toyota Land Cruisers? Super beefy 1/2 inch plate double shackles, that weigh about 15 pounds each?
    <a target="_blank" href=http://www.jtoutfitters.com/parts/accessories/suspension/hypershackle/index.html>http://www.jtoutfitters.com/parts/accessories/suspension/hypershackle/index.html</a>
  12. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    What about a shackle at both end's of the spring! This would of course require a 3 or 4 link setup to keep everything in place and you would have to deal with the pinon angle. I saw this setup on a Samari once and it gave a lot of flex.
    Corey 78K5
  13. BLUESMAN
    Oct 3, 2001
    951
    My thinking was far simpler than what you guys have come up with.I was just thinking of bolting two stock rear shackles end to end.I actually did this to the 56" springs that are going to be installed soon, but I only have the bushings(urethanes) for a single shackle at this time.So later I will try it and see if I can pull my driveshaft out of the T case!!!I'm sure I'll need to get a longer driveshaft to go with the flexier 56" springs and double shackle idea.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If your talking about making a hinged shackle out of 2 shackles, you are going to need a sort of bump stop between them to keep the spring eye from hitting the frame side shackle eye. It would look like a "V" rotated 90 degrees, the spring eye on one "leg" and the frame eye on the other "leg", with a hinge joint/bushing at the vertex. Is this what you are talking about? If so, how do you propose to keep the 2 eyes at the minimal separation? Also, with the added length due to two shackles, I don't know if they are strong enough to stand the leverage.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  15. BLUESMAN
    Oct 3, 2001
    951
    It was something that shot into my head and I still might try it.I do see what you mean and I had the same thought.The shackles would rest on each other eyelet to eyelet, but a urethane bumpstop would cure that problem.I used to run 18" "goofy leafs" under my Toyota,thereby giving me an additional 6" of flex.But now I've come back to the big boys and having more fun!
