Rear Drive Shaft Rear U-Joint Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83bowtyblazer, Mar 2, 2003.
  1. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    I just repalced both U-Joints on my rear drive shaft. The U-Joints fit perfectly. Now the problem I have is that the rear u-joint doesn't fit in the pinion. It's to big. Is it possible that there are 2 different sized caps for the rear?? If so, is that a special joint? Any advice would help. I need my truck.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, unless you've got a different rear axle swapped in or a different driveshaft, the cap sizes should be the same on both. If you've got a 12 bolt it should be a 1330 joint. If you've got a 10 bolt, it should be a 1310. Yes, there are conversion joints out there. What rear axle do you have?
  3. 83bowtyblazer
    Jul 29, 2001
    132
    Ft. Dix, NJ
    It's the factory 10-bolt. The drive shaft is 2 years old. It had the nylon locks in the joints.
