Rear drive shaft vibes...
Discussion in 'The Garage' started by Big'nBadK5, Aug 18, 2003.
  1. Big'nBadK5
    Big'nBadK5 Registered Member
    Feb 9, 2003
    84
    Pjs, Ny
    I put an echobit rear flip and soem add-a-leafs on my blazer a while back and since i am getting ready to treck 5.5 hours into up state Ny for college i thought it might be a good idea to try and remedy the vibration comming fronm the transfer case side fo the rear drive shaft. what could i do to fix it? i cant afford to put a CV joint up there just yet so something quick easy and inexpensive is the ticket. it dosent seam like the problem is to crazy so something small will likley fix it, i just dont know what.
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Is the u joint binding? If it is, you could grind away the small part of the yoke that is. Other than that, I don't know what you could do other than have it balanced/get a CV shaft.
  3. Big'nBadK5
    Feb 9, 2003
    84
    Pjs, Ny
    I think the u joint is binding up. the shafts were just cut and balanced so i dont think that the drive shafts are the problem, just the u-joints.
  4. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    You could drop the T-case with some spacers to lower the angle. It's not ideal, but it works.
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I had a similar problem I have been doing battle with for a good couple months. Rear CV shaft did not help either. What did help was lowering the tcase. It took about 15 minutes of time and almost no skill on my part.
    Problem has been solved! Give a try and see if it helps.
    BTW - I flipped around the stock spacers to drop it.
