rear drive shaft
Discussion in 'The Garage' started by rick88blaze, Feb 23, 2003.
  1. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i've heard of the custon cv rear drive shafts out there. what about fitting the cv joint from a front drive shaft to the rear drive shaft.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you can do it. but it is kinda small for running out back. check into high angle driveline. the prices are not that bad.
    Grant
  3. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    thanks, i just put a 2 1/2 in. lift with front and rear springs and now i have some driveshaft vibration. i thought maybe this would be a quick fix. that or i might drop the t-case a little.
