Rear Driveline Angle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by arnold88, Oct 9, 2000.
  1. arnold88
    arnold88 Registered Member
    May 31, 2000
    19
    Bentonville, AR USA
    I have an 88 K5 that I just put a 4" Superlift on. I bought the kit with the rear blocks till I can afford the rear springs. My question is, my rear driveshaft is at quite an angle now. I didn't receive any shims or any way to correct the angle of the rear axle. What would be best to do until I get the new springs? Can I lower my transfer case by installing spacers? Or should I buy shims for the rear axle? Any other suggestions? Any input would be appreciated.
  2. CK5
    May 19, 1999
    21,624
    702
    CO
    All you should have to do is lower the tcase by flipping the factory spacers (look like tubes) under the frame between the frame and tcase crossmember.
    5,000 Pounds of American Rolling Steel
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Your blocks should already have the shim angle "built" into it. Did you notice this when you installed them???
    If not, the top of the block will have an angled surface. When looking at the side of the block, the smaller part should go forward and the thicker parts should go towards the rear.
    HTH, if you have anymore questions drop me a line
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  4. arnold88
    May 31, 2000
    19
    Bentonville, AR USA
    I installed the blocks the correct way, but I still have the bad angle on my u-joints. I saw the spacers on the bottom side of the tcase skid plate. I will install them between the frame and the plate tonight. Thanks guys. One has to really appreciate a site like this.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    What are you defining as a "bad angle"? With a 4" lift, the driveshaft should not be in line with the rear axle pinion. If you make it straight, you will have to put a CV joint at the front of the driveshaft or else get ready to shake and spit out U-joints like sunflower seeds. Like coloradoK5 said, with a name brand lift kit, the angle of the lift blocks should be close enough that no more adjustment should be needed than to maybe lower the T-case a bit. What you want to achieve is for the T-case output shaft to be parallel to the axle pinion. That way both U-joints are at the same angle, but in a lifted truck, you are never going to run the joints at zero angle, which may be what you are expecting.
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  6. arnold88
    May 31, 2000
    19
    Bentonville, AR USA
    Thanks for the input. This is the first 4X4 I've ever owned. I'm used to old truck restorations. It makes sense about the angles being parallel.
