Rear driveline interchangability?
Discussion in 'The Garage' started by Muddytazz, Apr 23, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Sorry for the crappy pic, digi is acting up today /forums/images/graemlins/rotfl.gif
    Is this part [​IMG] interchangable on a 1/2ton and 3/4ton rear driveline?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Yes, it should be. The only difference should be the yoke on the axle end.
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    ...depends if the Tcase has a 1/2 or 3/4 ton yoke. You can run a conversion joint on that end just like the back...but as far as I know as long as the splines are the same you can swap them from shaft to shaft.
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    No it is not interchangable .
