rear driver's side tire locks up? WTF?
Discussion in 'The Garage' started by stoney126, Jan 2, 2007.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    Hey all have a small problem . The vehicle CC 89 gmc 1 ton 6.5td and 400. At low speeds 5-10 mph while applying the brakes slightly the drivers side rear tire locks up. It did it 3 times in a row then stopped.
    It Did it just the one time And has not done it since. What would cause it to lock up? Im running open diffs, on 38 toyo open country's..
    Thanks for any help in the matter
  2. dremu
    Feb 27, 2000
    15,966
    458
    East of San Francisco
    Sticky wheel cylinder? Star adjuster out of adjustment?
    Take drum off, lube adjuster with WD40 and re-adjust, check wheel cylinder and lube its plunger with brake grease or something.
    -- A
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    do you have RWAL in your truck? (or did that start in 90?+)
    that might have somthing to do with it.
    are you sure it is just the one side?
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Was it first thing in the morning?? My 97 used to do it, my 89 now and then, and my 93 S-10 does it too. Does it when it's raining sometimes too.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's the classic symptom of gear lube or brake fluid contaminated brake shoes. Something is leaking inside that brake drum. :( Fix the leak, clean the drum with lots of brake cleaner, then replace the shoes (they absorb the fluid, so they can't be reused).
  6. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    x2 on the fluid leak. I say either Brake fluid or gear oil is causing it.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    edit: nevermind, you guys already got it. :waytogo:
  8. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    ya it was first thing in the morning. I pull em and check for leaks. No antilocks here. im not 100% it was just the one side, heard em lock looked in the mirrior and saw it lock but didnt think to look at the passenger side.
