rear driveshaft angle
Discussion in 'The Garage' started by jester, Jul 7, 2004.
  1. jester
    jester Registered Member
    Apr 30, 2004
    53
    Prineville, OR
    The Jimmy I aquired had a 4 inch lift put in it and I have been breaking U-joints on the rear driveshaft. I was told it is because my driveshaft angle is off and was not compensated (spelling?) for when they put the lift in. I was going to put some shims in it to make it the right angle, but what angle is it supposed to be at? Thanks!
  2. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I'm not sure what the normal operating angle is for a stock u-joint (though I'm sure there's a number floating around somewhere) ... but you're having trouble w/ only 4" of lift????
    Maybe you could lower the t-case and use a degree shim to tilt the pinion up a little bit (if you have done this already)
  3. jester
    Apr 30, 2004
    53
    Prineville, OR
    Alright, I will try that, but how far should I lower the t-case? Thanks!
  4. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    What was used to lift the back?
  5. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    i assume you have just two u joints /forums/images/graemlins/dunno.gif
    you have to run them within 3* maby 4*if you had to
    the trick is to get both u joints at oppisite angles
    so if you have 2 down on the top make the bottom 2 up or whatever the angle works out to be /forums/images/graemlins/waytogo.gif
    do you get alot of vibration while driving /forums/images/graemlins/dunno.gif
    also might be a idea to get the driveshaft balanced /forums/images/graemlins/waytogo.gif
