Rear driveshaft from a K5 - Using to set axle for K20 wheelbase shortening
Discussion in 'Parts & Trucks Wanted' started by Resurrection_Joe, May 18, 2003.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Like it says, I need a K5 shaft that will hook to my truck's np205, so when I re space the axle I can use said shaft to turn the old 14 bolt. I'd also use it set the spacing between the axles.
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I have one from a 79 with a sm465/np205 and 12 bolt rear. It is 38 1/2" closed and 42 1/2" open. 50$ shipped
  3. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    just a thought /forums/images/graemlins/thumb.gif
    why not take wheelbase measurements from a k5 and then make your truck that length...and not use a drive shaft for setting wheelbase... it will be alot more accurate /forums/images/graemlins/grin.gif
    but you can do what ever you want its your truck.
  4. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Backyardbuilt -
    Lemme go out and look tomorrow at the truck and see about some things.
    As it is I will most likely take it!
    Gtkustoms -
    That's basically the plan, I suppose my wording didn't make it clear, maybe a bit more forward to compensate for the lift.
