Rear Driveshaft... how far is too far?
Discussion in 'The Garage' started by Vetteman61, Jan 23, 2007.
  1. Vetteman61
    Vetteman61 Registered Member
    Jan 11, 2007
    93
    Kentucky
    After my 4 inch lift, my rear drive shaft appears to be too short. How far should it slide into the transmission and still be safe? It seems to be sticking out about 3 or 4 inches further than stock. I'd like to get away without lengthening it, but I'd much rather be safe than sorry.
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Pics. and truck info would help.
  3. goldwing2000
    goldwing2000 Guest
    Shimming the axle would be cheaper than lengthening the shaft, and would accomplish the same result. Plus it would decrease your pinion/u-joint angle.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Shimming the axle won't do much at all for the engagement of the driveshaft and it certainly won't make the shaft any longer. :D
    The only thing you can do to correct the problem is have the shaft lengthened. The slip should only have about 1" of travel inward. If the shaft is out too far you will ruin the tail housing bushing and subsequently the t-case.
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    how did you lift the rear? if you used a block then it should have taper built into it. when I did my 6" lift I didn't need to lengthen my shaft. the slip yoke only came out of the tailhousing about an inch. when I went to an 8" lift I had a new shaft made.
    the only way your could be out 3-4 inches more would be if the axle got moved back. did you use new springs and put them in backwards?
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Wrong answer, there are many different springs available and also shackle flips and each vehicle is different and also depending on what tranny/t-case combo it could easily move the slip out that far. I did a spring lift and my driveshaft moved outward of the t-case about what his did. I had to have a DS made so i had HAD build me a C/V shaft and then did a SYE.
  7. goldwing2000
    goldwing2000 Guest
    Yes it will. :D
    If you rotate the pinion upwards, it will not only decreases your pinion angle but also moves it closer to the t-case output, thereby decreasing the necessary driveshaft length. Simple geometry.
    If one were willing to do some cutting and welding, you could also rotate the axle under the spring perches.
    You're right about the 1"-1.5" sticking out, though.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It works. Changing my pinion angle moved my slip yoke about 2"
    Ira
  9. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    IIRC the slip yoke is about 6" long. I think I would want at least a good 2" of engagement. Any less than that and I'd think you'd be sure to slip the shaft out.
  10. Vetteman61
    Jan 11, 2007
    93
    Kentucky
    my 4 inch lift
    I used only 4 inch blocks in the rear. My rear end was bad so I also installed a new (to me) 14 bolt limited slip out from under a 79 4X4. My friends actually put the blocks on while I did other things. The truck is at my dad's shop about 30 minutes from here so I won't be able to look at it for about a week. Is it possible they put the blocks on backwards???? I also thought, though I didn't know for sure, that the blocks should have wedge built into them.
    I used springs up front, but as of yet haven't tried to unstick my front driveshaft to see if it will be long enough.
  11. goldwing2000
    goldwing2000 Guest
    Yes, the blocks should have a certain degree of wedge built into them (as long as they're good quality blocks) and yes, it's definitely possible that they could be installed backwards.
  12. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    As stated they probably do have some angle to them. I have 2.5" lift blocks and I didn't realize they were angled until I installed them in wrong. :doah: The angle wasn't really perceptible until I put a tape measure on them.
  13. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    My K5 was originally lifted 4" with angled blocks in the rear and I had to have my DS lengthened a bit. From what I understand, swapping in a 14bolt should eliminate that need due to a longer pinion area than a 10 bolt.
  14. Vetteman61
    Jan 11, 2007
    93
    Kentucky
    why why why
    ah yes, also, when I swapped the 14 bolt in, I obviously had to get a crossover ujoint. The yoke for the 14 bolt was SMALLER than my 10 bolt was. Is that normal?
    I'll definitely check my blocks next time I'm with the truck to try to see if the blocks were possibly installed backwards.
  15. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    uhhh nope...the 10b should have an s44 and the 14ff should have a 1350.
  16. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    Oh no, Avery I've got a 1310 yoke do I need to make it a S44?
  17. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    IS it out as far as mine is? [​IMG]
  18. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    Jack up the rear, so the rear suspension is at full droop, and if the yoke falls out or if your yoke has less than an 1", I'd look into a Tcase drop kit just to net a lil more if you have less than an inch. But you shouldn't need any more length to the rear shaft. If we had T-cases had flanges on the rear like the front output shaft, we could use drive shaft spacers.
  19. goldwing2000
    goldwing2000 Guest
    That's just scary, man. :eek1:
  20. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    x2! silly boys and thier slip yoke outputs....
