Rear Driveshaft Noises
Discussion in 'The Garage' started by GMC, Mar 8, 2005.
  1. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    I went to 1 ton running gear with a D70 in the rear. I have been running the stock driveshaft with no problems. I just replaced it with a 1 ton shaft out of a CUCV I had shortened, balanced, and new spicer u-joints. I also put a 1350 yoke on the D70. It's an 1981 Blazer, np208, 4" in. blocks in rear.
    Now when I drove it I have a noise that doesn't sound good. It's only when I let off the gas I hear a metal vibration sound. I don't really feel anything I just hear it. If I get back on the gas it seems to go away until I coast again. When I came home and looked under it everything seems fine. The u-joints aren't binding and full of grease and pulling on the driveshaft it's all tight, no leaks from the 208 or D70.
    I'm going to check the fluid in the D70 and 208 next and put more grease in the u-joints. Anyone have any ideas??? Thanks.
  2. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    WHen you put the new yoke back on, did you make sure the preload was correct?
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    It could be that the dust shield thingey is loose on the rear yoke
