rear driveshaft question????
Discussion in 'The Garage' started by HEAVY METAL, Mar 24, 2005.
  1. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    i just bought the wife an 83 k5 blazer.( i have a 74 with 81 front clip,6 pt cage, 205,sm465, 14 ff, d44, 4.10's, 350 hp sbc350, 6" suspension, 38.5x16x16.5 tsl's)
    her truck also has the sm465 in it. my question is the rear drive shaft does not have a slip yoke? is this normal? it has a np208 and 10 or 12 bolt not sure. the rear drive shaft just has ujoint up top and u joint on bottom??? is it sposed to be like this?thanks for your help!
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If there's no slip yoke at the t-case output, the driveshaft should contain it's own.
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    thats ok as long as the tail shafty has the slip yoke in it
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have the complete 83 sm465/np208 combination in the garage , came out of the frame original . The shaft is supposed to have a slip yoke on the transfercase end .
    Being as old as it is it could of been swapped out at some point in time .
    Take a pic of the case an shaft and post it up :k5: :k5:
