rear driveshaft u joint question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mr_fujisawa, Jan 3, 2004.
  1. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    first of all i have an '88 k5 blazer stock 10 bolt rear. . .now onto the question.
    hey all. i searched before i went to the parts store and it appeared to me that the rear drive shaft u joints were 1310's. so i go to the local kragen and the guy tells me that it's not 1310 and that it could be one of like 8 different joints. so i am sitting there and he brings out some joints but they all have the external style retainer clips that are kind of "D" shaped. then he says maybe it's the 1350 and then says they are out of those. at this point i am pretty frustrated.
    so i go to a different kragen and the same thing happens. a few joints with the external style clips. finally i get one that has c-style clips that go on the inside. and i was comparing it to the one in the rear yoke and it looks like it is just barely too small (but it was dark and my eyes could have been decieving me.)
    so. . .can somebody please tell me what the proper size u-join that i need is? thanks in advance. /forums/images/graemlins/thumb.gif
    sean
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You should have a 10 bolt and if so it is a 1330.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I was told that the later blazers have a "mechanics 3" u-joint size. It sounded funny but when I went to get my conversion u-joint for my 14BFF, I said I needed mech.3 on the driveline side and 1350 on the yoke and he knew what I was talking about. Try mechanics 3.
  4. rekvehicle
    rekvehicle Registered Member
    Apr 11, 2003
    23
    Spring Hope, NC
    I had the same problem with mine.The rear U-joint on mine has 2 different size bearing caps.Went to NAPA and they squared me away.RV
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah go to NAPA and they will fix you up
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not true, the 10 bolt uses a Saginaw S44 joint.
    Proper part number is 2-3011 in a Neapco.
    2-1153 will convert you to a 14 bolt rear axle where a 1350 conversion is required.
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'll second this info! /forums/images/graemlins/thumb.gif
    John
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Besides having my own Neapco catalog, where do you think i stole such info? /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif Credit to 83ZZ502_Jimmy
    of course.
