Rear driveshaft ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KING K5, Apr 2, 2001.
  1. KING K5
    KING K5 1/2 ton status
    Sep 28, 2000
    172
    Sacramento, Ca.
    Can a rear driveshaft from a '78 Blazer with NP205 t-case and 12bolt combo be used on an '81 Blazer with NP208 t-case and 12 bolt combo?? Thanks for any info in advance!
    Jeff
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Is the 205 a fixed yoke or is it a slip yoke? I think in 1980 they went to a slip yoke on the 205 in Blazers. If it's a slip yoke 205, you have to check the spline count on the 208 to see if they are compatible. If it's a fixed yoke, you won't be able to use it. Stock yokes on the k5 are 1310 u-joints.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    If the splie count is worng but the length is right, you could have a shop modify it to work!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  4. KING K5
    Sep 28, 2000
    172
    Sacramento, Ca.
    The 205 it's coming off has the reverse slip-yoke like the 208, I guess I'll just need to find out what spline count it is to see if it will work. Thanks for your help!
    Jeff
