rear driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snowtoy, Jun 6, 2001.
  1. snowtoy
    snowtoy Registered Member
    Mar 18, 2001
    30
    Norway
    I have to change my rear driveshaft (between tnafercase and rearaxle) It is a driveshaft or?
    well what will fit I have a Np203, 10 bolt?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Im confussed. What is up with the old one? Is it too short or damaged or what?
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    You can take the old (provided that you still have it) and have the driveshaft shop do what you need with it to make you a new one, or use it to compare to one you may find in the yard.
  4. snowtoy
    Mar 18, 2001
    30
    Norway
    Yes it's damaged, I have a big vibration when i go faster then 65 MPH and i have tried going whitout, and my vibration is gone, I have checked it but I can't find something wrong, I work as a car mechanic in Norway (You have to excuse my bad english) So I think I will change it, but since it's hard to find K5 parts I wondering can I use a drive shaft from another car? like a pickup, van?
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Have it balanced at a driveline shop...?
    Dave
    "Visualize Whirled Peas"
  6. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    If you can find one from a pickup, you will be close - but you will have to have it shortened most likely, since the pickup driveshafts were longer than the Blazers...have you checked the u-joints? Could be a bad joint...
  7. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Check and make sure you didn't lose the little balancing weight on the driveshaft, also check your u-joints.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  8. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    what about the drive shaft angles? Is this thing lifted? my vibrates a little about 65 but my driveshaft angle suxs...
    You call that dirty!?
  9. snowtoy
    Mar 18, 2001
    30
    Norway
    I have checked my U-joints looked was ok but the splines on the middle of my driveshaft is not good, I can turn front and rear parts in opposite direction a little bit, I don't know but maybe this is my problem ?
  10. snowtoy
    Mar 18, 2001
    30
    Norway
    Thanks. I have just post it to a repair shop.
  11. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Cool. Hopefully they can fix you up.
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
