rear driveshat into NP208 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Apr 22, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    How much should the maximum be that the shaft that goes into the transfer can stick out. I suppose that it needs to stick out some so that it can travel in and out when the rear diff./suspension travels up and down.
    Does anybody know how long it is and how much should be visible on the outside. Hope you understood my explanation.
    86 K5 with 350/700/NP208
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    mine sticks out (just guessing) about 2 1/2" its more of a concern of how much is still in when you get a lift and such 4" isn't a problem 6" can be a bit much.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I measured how much was sticking out from the seal to the backside of the yoke when it was stock and got exactly 3''. The entire slip shaft is 5 7/8'' to the point where it begins to taper and 6 1/4'' to the end. I would just keep it close to the factories setting (around 3'') but lift the rear of your truck untill the suspension tops out and measure how much of the slip yoke is showing to make sure that it won't pull out at full droop. Sorry I couldn't give you a minimum number left in the T-case to work with, hope this helps.
  4. bajaviking
    Apr 10, 2002
    752
    Baja
    Thank you for your reply, that's what I needed to know.
