rear drums...will they fit??
Discussion in 'The Garage' started by MITCH_89', Mar 1, 2003.
  1. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    Good morning all. Ill be putting my "new" 12-bolt in this weekend. The drums cant be turned due to wear, and new ones are 86 each. Will my 10-bolt drums fit? Thanks
  2. MITCH_89'
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    Anybody know???
  3. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    They should be the same I believe the only difference is in the axle shafts, anyone wanna back me up?
  4. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    There were at least two different rear brake setups. I swapped a 12 in for my my stock 10 and the brakes were different. The 12 was from a 1978 and had the smaller drums and the 10 was from a 1987 and had much larger drums. I swapped the entire brake system from the 10 to the 12. I pulled the axles and switched the backing plates. Everything bolted up just fine.
    If the drums *look* the same then I would say they will work. The two I had were very different looking.
  5. MITCH_89'
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    Thanks, I should know soon enough. Man I cant wait to see the difference in 2.73s and 3.73s!!! I know I will be much happier
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yep, i put the old drums off my 87's 10 bolt onto my 79's 12 bolt diff that i put under the truck, and all the brake parts, less backing plates, left those on, and everything fit great /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
