Rear Electric Window Won't Budge!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5XLR8R, Jun 13, 2001.
  1. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    Rear Electric Window Won\'t Budge!!
    The Damn thig won't go anywhere.....the switch doesn't work and the key did'nt work either.....is there a way to do it manually from within the gate???HELP!!!!!
    Jordan
    Yep!! It's definatly a jEEP thing...So, what your excuse???
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Re: Rear Electric Window Won\'t Budge!!
    If you can get to the connector underneath the tailgate on the left, check and see if it's getting power - Maybe a blown fuse?
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  3. K5XLR8R
    Aug 22, 2000
    210
    Washington State
    I had'nt check the fuse yet! (insert Homer Simpson noise here) ...I'll look tomorrow....where would it be located (general area) on the fuse box? I quickly looked the other day but nothing jumped out at me...it's a deisel so it was alot of suff I had'nt seen before...thanks!
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'm really not sure where the fuse is - I've never had one blow (feverishly knocking on desk). The connector also gets loose/corroded and makes it quit working.
  5. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    if all else fails, remove the tailgate cover. you should see a cable that screws onto the motor on one end and the window regulator on the other. Disconnect the motor end. There should be a square thing sticking outta the end of the cable. Attach a drillonto the square thingie. using the drill you should be able to make the window go up or down as long and nothing else is busted. One more word of advice. Watch your voltage guage when you try to raise the window from the dash, if it drops a lot when you try it then the motor is prob stuck or dead. My Blazer uses a circut breaker for the tailgate so I assume they all do.....
    You call that dirty!?
  6. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    mpascino is right. I did the cordless drill trick all the time with my second Blazer. I just left the inspection cover off so I could get to the cable real easy. I didn't roll the window up and down that often, and since it was free I didn't mind doing it too much.
    '73 K5
    Chevy good...Ford bad
  7. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I just found out why my power tailgate window for my truck wasn't working. The cable for the window was completely seized. If it's your cable, you can't do much to get the window up untill you get a new one. Right now I have a tarp over the back of the truck to keep rain from getting in. Hope to get a cable later this week.
    <A target="_blank" HREF=http://billybob87k5.50megs.com>Homepage of Porky & Stinky</A>
    Billybob, the REAL <font color=red>Bionic Redneck</font color=red>
    <P ID="edit"><FONT SIZE=-1>Edited by BillyBob on 06/13/01 08:58 AM (server time).</FONT></P>
  8. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Mine did the same as BillyBob, It seized up and wouldn't budge. Luckily it stopped near the top so I slacked for months before I got it fixed. I went to the dealer and bought a cable for like 20 or 30 bucks. It was an easy cheap fix! later
  9. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    If you get to the point of the using a drill to lower it, see if you can push some grease into the tube before you start spinning the cable. I greased mine recently, and it made a load of noise and speed difference when rolling the window up and down! I'd bet I bought myself some time before a cable siezure too.
    But definately check the breaker/fuse first!! Go buy a new breaker too, maybe yours has had it. Use a big ol fuse to test it if you don't have a new breaker though.
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  10. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have an 85. My window frequently gets stuck down. Mine is because of bad connections (my guess). Slamming the gate shut again usually resolves my issue. You've probably already tried this, but I thought I'd offer anyway!
    85 GMC Jimmy, 305 w/TH700-NP208, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
