rear end EATON
Discussion in 'The Garage' started by proyouring71nova, Apr 10, 2003.
  1. proyouring71nova
    proyouring71nova Registered Member
    Jul 17, 2002
    39
    CA San Rafael
    So I got off the phone with The local rear end shop and I told them that all I want to do is install a locker in my eaton rear end with out replacing the bearings and so on, they told me that if I'm NOT changing the ring and pinion that the shims should be the same and that all I need to do Is swich the carriers and put it back together. So my ? for you is dos this sound right? thanks max
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    If its a drop in locker where you install a locker into the same carrier, yes. If you are replacing the carrier no. Then youll need to go thru the whole set up and adjusting process.
