Rear End for '90 S-10 Blazer?
Discussion in '1983-2005 S-Series models' started by roostr3269, Jan 12, 2002.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    Rear End for \'90 S-10 Blazer?
    I have a friend who has a '90 S-10 Blazer w/ the 4.3 and 5 spd. He needs to replace the rear end and is wondering how much it will cost for a new rearend, not sure what gears are, Either where to go for 1 or ? any help would be appreciated, thanx.
    live to wheel, wheel to live--1972 gmc jimmy 8 inch lift, 37" ssr's
  2. Jamus
    Jamus Registered Member
    Jan 10, 2002
    29
    Morgantown, WV
    Re: Rear End for \'90 S-10 Blazer?
    Where ya located? I have a couple that I wouldn't mind getting rid of. One even has a Lock-Right. I'm in WV.
    94 Blazer, 4.3 cpi, 3" body lift, SFA with dana 30/Fors 9", 33's
  3. scotty1
    scotty1 1/2 ton status
    Jan 7, 2002
    166
    WV, Harpers Ferry
    Where are you at in WV? I am near Harpers Ferry.
    Git there fastest with the mostest!
    Nathan Bedford Forest
  4. Jamus
    Jan 10, 2002
    29
    Morgantown, WV
    My parents live outside of Beckley and I go to school at WVU, Morgantown.
    94 Blazer, 4.3 cpi, 3" body lift, SFA with dana 30/Ford 9", 33's
  5. roostr3269
    Jul 2, 2001
    305
    michigan
    I am located in Michigan,price? pics? ship? thanx
  6. Jamus
    Jan 10, 2002
    29
    Morgantown, WV
    I bet shipping would kill ya. Axles weigh about 200lbs I think. I'd probably either have to build a box to ship it in or atleast get a skid. But if you're still interested, shoot me an e-mail at uglyjeep@hotmail.com
  7. scotty1
    Jan 7, 2002
    166
    WV, Harpers Ferry
    Is your SFA the Stage West kit? I had thought about doing that but then I found out they stopped making it. I have killed many brain cells in Mo-town. I have sone a lot of white water kayaking in the area.
  8. Jamus
    Jan 10, 2002
    29
    Morgantown, WV
    Naw, I'm too cheap to buy the stagewest kit, it was discontinued anyway. I made my own setup that's very similar to the SW kit. I used a combo of 2 S-10 leaf packs and the same shackle mounting point as the SW kit.
    It's hard not to kill brain cells up here.
  9. scotty1
    Jan 7, 2002
    166
    WV, Harpers Ferry
    Wow, I am impressed you fabed up your own rig. There should be plenty of trails to use your rig on near by. Have you be up around Coopers Rock park yet?
  10. Jamus
    Jan 10, 2002
    29
    Morgantown, WV
    Well, I had a lot of help from my buddy but, other than that, it was all us. I don't have the front driveshaft in yet, waiting on the use of a bigger welder. I have been to Cooper's Rock. I actually went when I was 2wd without getting stuck once. I know there are better/harder trails around here, just don't know where they are. I can't stand this not having 4wd, hahaha.
  11. scotty1
    Jan 7, 2002
    166
    WV, Harpers Ferry
    The new custon length front drive shaft was something the SW kit needed too. What make/year front axle did you go with?
    Nathan Bedford Forest<P ID="edit"><FONT class="small">Edited by scotty1 on 01/22/02 06:58 AM.</FONT></P>
  12. Jamus
    Jan 10, 2002
    29
    Morgantown, WV
    Well, I have the driveshaft. I'm just waiting on a welder to weld in a driveshaft hoop into the tranny crossmember. And do a little exhaust re-routing but that's minor. I'm using the driveshaft out of an 85 Jeep Grand Wagoneer. In the future I also plan on swapping the dana 44 from the Jeep too. Right now I have a dana 30 from a, 89 I think, Jeep Wrangler. It had 4.10's so I didn't have to swap gears. The dana 44 I have has 2.73's!!!!!!!!!!!!! So not only do I have to buy gears, but I will also need a different carrier. That's too much money and work for me right now. Maybe once I graduate.
  13. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    Hey, that driveshaft hoop won't interfere with the movement of the deiveshat when flexing, will it? I know when you have SFA on S-10s theh have MAD flex most of the time. Just wondering......
    <a target="_blank" href=http://www4.ncsu.edu/~brschoch>www4.ncsu.edu/~brschoch</a>
  14. Jamus
    Jan 10, 2002
    29
    Morgantown, WV
    It shouldn't. I've seen two other SFA Blazers with the hoops and they were fine. The crossmember is located fairly close to the transfer case. Mine has a desent amount of flex. My only limiting factor at the moment is the rubbing on the fenders. I've already cut the rear of the front wheelwell back by 2". I'm thinking about redrilling the center pin in the springs but I'm not sure if it's safe. Had some say it was and othere say it wasn't. I want to get a set of Revolvers front and rear, after the front axle swap. Of course that would require even more mods, more than likely new driveshafts. Might as well get a fixed yoke conversion on the back. And while I'm in the t-case, put in some 4:1 gears. Ya see, it never ends. If I had a pinto, I'd find a way to put seven million dollars into it, hahaha.
