rear end gasket
Discussion in 'The Garage' started by Bhintz, Jun 21, 2003.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    very dumb question, no making fun of but but do you put silicon on the gasket of the rearend if you do what side
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    gasket? LOL i just use silicone... no leaks yet...
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah I never use the paper gaskets, just RTV.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    The previous two posters must be smarter than I. The only time I went RTV only on a diff gasket, I had problems. I always use RTV/gasket to keep the thing sealed.
  5. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    how hard is it to get off and do you use one or two beads why do you use just rtv do the gaskets leak or something
  6. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    What do you mean by "is it hard to get off." Do you mean the gasket or differential cover? And I use the gasket and a ton of rtv. Never leaks. /forums/images/graemlins/thumb.gif
    -Harrison
  7. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I just do a single thin, about 1/8" diameter, bead on the diff housing itself, stick the cover on and bolt it down, never had a leak yet /forums/images/graemlins/thumb.gif.
    Comes right off with a putty knife to /forums/images/graemlins/thumb.gif
  8. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i used the gasket and sealant on both front and rear. the outsides are still as dry as the desert that i live in. /forums/images/graemlins/thumb.gif
  9. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    i use rtv personally... i think if u have any kind of damage to the cover or housing (ie not full on breakage, just rough spots, slight bending etc) then rtv seals better than a regular gasket. It gets in all the nooks and crannies, while a reg gasket assumes its going between 2 perfectly flat parts.
    j
  10. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Silicon and a gasket for me.
    The rtv will fill in imperfections like the previous post states. I always smear (with my finger) a very light coat on both metal surfaces. This works very well. I just pulled the cover off my 12 bolt last weekend and the paper gasket delaminated perfectly. There is a 100% complete gasket on both the diff and the cover, just 1/2 as thin. There is no way this will ever leak. Also, don't over tighten the bolts if you use a gasket. It will crush the gasket and cause leaks. I torque em down to about 15 pounds and have never had a problem with leaks.
    Good luck
  11. dyeager535
    26,975
    I always use the gasket with the RTV on the cover, since the cover is easier to clean off than the housing, for the next time you pull the cover.
    Really should only *need* one or the other (RTV or gasket only) but it doesn't seem to hurt to go all RTV, or gasket/RTV. *Very* little RTV though...I spread it with my finger so that its thin enough to almost see through.
