rear end gear ratio
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jun 6, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    ok, im trying to figure out what gears i have in my 12 bolt and im not sure how to do this. I know i can jack up the rear and spin the tire and count the turns of the drive shaft but how do i interpert that?
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  2. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I believe you put a mark on the pinion or driveshaft.. then put a mark on the tire.. then rotate the tire and count how many times the pinion spins for one tire rotation using the mark.
    That's how i've seen it done.
    Experience is something you don't get until just after you need it. <A target="_blank" HREF=http://www.rocko.coloradok5.com>http://www.rocko.coloradok5.com</A>
  3. dyeager535
    26,975
    If you REALLY want to know for sure what they are, pull the diff cover off, (tires off the ground) and rotate the ring gear (big one) until you see the stamped in ring/pinion count. Divide big number by little number, and you have the exact ratio. Doesn't hurt, since diff fluid is rarely changed, and it will give you an idea if anything is going wrong in there, or if everything is in ship-shape.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  4. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    90 weight gear oil.
    '71 Blazer CST with alot of rust
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    It's two rotations of the tire, and if you do it carefully it is fairly accurate. Three rotations of the drive shaft, 3.08, almost 3.5 rotations 3.42, almost 4 3.73, etc.
    Derf00
    http://www.derf00.coloradok5.com
    "Four wheel drive allows you to get stuck in a more inaccessible place."
