Rear end Gears and the like
Discussion in 'The Garage' started by 82blazercletus, Aug 9, 2003.
  1. 82blazercletus
    82blazercletus Registered Member
    Apr 3, 2003
    6
    ok I am pretty new to building my own rig, and so far I am enjoying it emensly. I have an 82 K5, 6.2L with 700R4 and 10 bolts front and rear. I am looking at swaping the rear 10 bolt for a 12 bolt that I have aquried,and planing on converting it to disks, what gears should I use in the rear end. Please bear in mind that I know very little about the difference in gears, like 3.10 vs 4.10. Whats good and whats should I expect to leave me out on the trail? /forums/images/graemlins/k5.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Sit down and make a 'big' plan. Decide what the end result will be, bigger tires, lift, and what not.
    Accumulate parts that will fit into that big picture, and go from there.
    This 'might' eliminate the need to do some things more than once, thus saving you some money (hopefully) /forums/images/graemlins/thumb.gif
  3. 82blazercletus
    Apr 3, 2003
    6
    Well this is my daily driver, right now my plan is too keep it where its at. 4" Rough Country suspension and 35" mudkings. I am just not too sure on what to put in there or leave whats already there, and just how does some redneck hillbilly (ME) figure out what gears are there if it doesn't say on the dif plate or the glove box?
  4. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Best way is to pull the cover and check everything out.
    There should be a stamp on the ring gear, and look for the last set of numbers IIRC. divide them and that will give you the ratio. Putting in new gear lube is always a good idea, and if you can stand the smell, then anything you will do to your rig will be easy....
    As far as what ratio to use, I can't help there, as I am not familiar enough with the 6.2....
  5. 82blazercletus
    Apr 3, 2003
    6
    Thanks for the info, I need all the help that I can get.
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, here's what I would recommend - Find some axles out of a 3/4 ton that already have 4.10 gears in them. The 4.10s would work well with 35s, although with the 700R4 you could go even lower (numerically higher) than that.
    The reason that I'm recommending going this route is that it will not only end up being less expensive in the long run, but you'll also have a much stronger rear axle in the truck. If you were to go with the 12 bolt and then regear it, you're looking at $150 for gears plus another few hundred for the disc kit, then another couple hundred to have the gears installed. So you're looking at $650 to get that rear axle in, and you either have mismatched gears to the front or you've regeared the rear to match the front and in doing so end up with a gear ratio that is way taller than ideal.
    You could probably find a set of 3/4 ton axles for under $500, you'l already have a good gear ratio and the rear discs are much less espensive to do on the 14 bolt. This is all just my opinion, but I beleive that it's the best way to go to get the most bang for the buck.</font>
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah as Subfan said there will be numbers stamped on the ring gear example 45 12= 3.73 or 41 10=4.11 that is the number of ring and pinion teeth you just divide them. there are other numbers on there too they are like the date of manufacture.
    If you are planning on running 35's 4.11's to 4.56's are perfect. Just remember if you change the gears you have to change the front too /forums/images/graemlins/thumb.gif 4.11's are common and easier to find and will be fine unless you are planning on serious crawling. /forums/images/graemlins/thumb.gif Like shaggy said too it is far easier and cheaper to swap in a whole axle assembly than change out the gears and later break the 1/2 ton stuff.
    Also you have the 700R4 good tranny In my opinion, but they require maintenance to last with big tires. Look for an external cooler and maybe a temp gauge. Keep up on your fluid and filter changes.
    As far as rear discs I use the Az-Kickin brackets. They work very well. Do a search in the forums for rear discs and you will find many informative posts /forums/images/graemlins/thumb.gif
    Good luck and welcome to the best K5 site on the net! /forums/images/graemlins/thumb.gif
  8. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    This started out with a 4" lift and 35s, it will get worse, this is still my DD too /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/1zhelp.gif
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    You're so conservative /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    In the last few weeks, I've gotten a couple of quotes for gear changes and haven't had one under $800 for my 12 bolt /forums/images/graemlins/eek.gif
  10. 82blazercletus
    Apr 3, 2003
    6
    I am thinking the only way to learn how to do it, is to get dirty and get it done, May tear a few things up along the way but I have every intention of swaping the gears myself, with enlisting the help of some friends. /forums/images/graemlins/k5.gif
