Rear End ID
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cederic, Jun 8, 2001.
  1. cederic
    cederic Registered Member
    Apr 4, 2001
    31
    Nebraska
    I was changing lube in my 85 rear end and don't know what rear end I have. It has ten bolts for the cover, a gear or sprocket inside the cage on the ring gear side, little spools on the cage in front of the spider gears that have springs in them and they spin about ten times for a 1/4 turn of the ring gear. It does have clutches in it of course.
    Do I have a locker or what?
    Anyone with specs or an exploded view please reply.
    The reason I took it apart was because I felt alot of end play when I was putting on my new tires. By alott I mean about 3/16" just as an estimate, It seemed like alot but there wasn't any parts or shavings in the shell or in the old lube.
    Thanks,
    [image]http://www.animationcity.net/gifz/hand.gif[/image]
    What do you call a fly after you pull off it's wings ?
    A WALK...ahhehe
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like a 10-bolt rear end with a Gov-Loc factory locking diff. They work great until they suddenly don't work any more. [​IMG]
  3. baldk5
    baldk5 Registered Member
    Jun 3, 2001
    29
    nova scotia, Canada
    well you have a corporate 10 bolt rear end. thats what i have, most likely you don't have a locker but a limited-slip unless the previous owner put one in it. The gears (if they are factory) are probably 3.08's. The ratio is stamped on the ring anyway if you want to pull the cover off again.
  4. dyeager535
    26,980
    Sounds like an Eaton Gov Lock. Go easy on 'er. Big tires, burnouts on or off pavement=dead axle. Work fine as long as you don't demand much of it, such as extreme wheeling.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
