Rear end jumps
Discussion in 'The Garage' started by 84CUCV, Apr 8, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    My friends K5 has stock 10b and 35" tiers. Out of no where it started to jump when he got on or off the gas, what could that be?? I have no clue.
    thx Mike
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    What do you mean by "it started to jump"? Is the rear axle housing rotating upward when he gets on the gas?
  3. primr87
    primr87 Registered Member
    Feb 15, 2005
    20
    placerville, ca
    if its got 4" blocks in the rear he may have bad axle wrap causing the u-joint to bind
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    2" block. This is how he put it to me. When he hits it or lets off the whole truck just jumps. I dont know how else to put it. I do see what you mean about the block. I see how that could do it, but would it do that with just 2"?? When i see him i will get a better description. Mike
  5. primr87
    Feb 15, 2005
    20
    placerville, ca
    try watching the rear pinion while he pulls back and forth so you can get an idea of whats happening. mine used to bind when i got on the brakes to hard
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Check and make sure the u-bolts are good and tight... I dont really think the bock is causing a problem... Im running a 4in block ( :( ) and a locker right now but i still dont have any problems with wheel hop or anything(I do have AT's which dont grab that hard offroad but ive done quite a few stand still burnouts and I dont get anythere either)
  7. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    Check out the rear mount under the transfer case it lets the rear jump up puting the drive shafts upper ujoint in one hell of a bind thats what happend to mine any way when i went to gmc to get one they had 15 in stock
    that means they sell alot of them put a jack under it it hard to see if its bad just looking at it.
    90 jimmy
    02 gmc HD
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Cool thanks guys i will give it a try. Mike
