rear end leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Oct 31, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    Worcester, MA
    my rear end leaks fron the pinion, i'm guessing just the seal, it is just the seal, how hard is it to change?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    Nashville Tn
    Probably just the seal. Easy to replace.
    Make a mark on the nut and the yoke. Count the number of threads exposed. Then remove the nut. You may need to get bearing or gear puller to remove the yoke. Once this is off, pop the seal out. Replace it with the new one. MAke sure you put some grease on the rubber part. Tap it in fluxh with the outter suface of the housing. Put the yoke back on, tighten down the nut till the same number of threads are showing and the mark on the nut and the yoke match up. Re-install driveshaft, then you are done.
    Forgive me if I missed anything, Im drunk and Im typing in a hurry.[​IMG]
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
