Rear end locking up???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jul 8, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    my rear end - stock 10 bolt - seems to kind of "lock up" sometimes and the tires chirp like something is wrong inside, causing binding or something in the gears. I haven't pulled the cover off yet, becasue it only happens every now and then, either slowing down to a stop, and then it will continue a little after i start moving again. Any ideas? Maybe my 10 bolt is breaking.....then I guess I would have to replace those gosh darn 3.42's for 4.11's in a 14 SF....[​IMG]
    90K5
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Man that sounds just like mine. Can you say bad spider gears. LOL.
    <font color=blue>Wayne<font color=blue>
  3. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    If you've got a factory locker( A.K.A Gov-loc) then it sounds like something that happened to me a few years ago! Don't have that problem with my 14FF W Detriot!! If you already have a 14SF it's alot better than a 10 . But if you catch it in time and you want to keep the 10 in, replace that carrier!
    1991 Fullsize 51/2" , 37"ssr's,10Bolt8 lug , 14Bolt ff, 4:56 Detroit rear , 12"fr. 14"rear Bilstein remote res. 350 P.F.I , 700r4 , 241c W/ sye ,
  4. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Could be your brakes freezing up or the rear end. You said it only happens when slowing down, like when you're applying brakes? I'd check the brakes first.
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Dont waste your time on the 10 bolt. Get your 14ff ready!
    (this is what you wanted to hear, you just needed an excuse I bet)
    Dave
    Beauty is in the eye of the beer holder.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Took the cover off this morning, found a lot of metal on the magnet considering i changed the oil in there about 10K ago. I went to the junkyard and found onlt 3.73's came home to fill up the 10 bolt, and the fill plug was seized, so I filled it up through the vent...hopefully it will be OK for a little while...
    90K5
