Rear end noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aztec777, Feb 23, 2001.
  1. aztec777
    aztec777 1/2 ton status
    Aug 15, 2000
    316
    Reno, NV
    I have a loud clunking noise in my GMC Jimmy that increases/decreases according to speed, whether in gear or not. I have parked it and will start working on it. I think it's either a wheel/axle bearing or the diff gears. Any help on what to look for? I'm comfortable with doing the work myself and have replaced wheel bearings. I'm just not sure about the ring and pinion gears. I have determined that it is a 12 bolt. Do I need any special tools? Would I be better of having someone else do it? Thanks in advance for the help.
    Steve
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've never heard bearings clunk. They usually start growling or whining when they're going bad. Do you get about 1 click per tire revolution? If so, then it sounds like a tooth broken on the ring gear. [​IMG]
  3. Whassup
    Whassup 1/2 ton status
    Feb 2, 2001
    140
    Wyoming, USA
    If you haven't done it before, then get a shop to do it or have a friend who knows what he's doing help you. You'll basically need an in/lb torque wrench and your basic tools for disassembly.
    "There's NO replacement for displacement!"
