Rear end oil????
Discussion in 'The Garage' started by adamforsythe, Feb 24, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    My diff cover is leaking REAL bad so I am going to change the fluid in my rear end and reseal it. Might do the front end also just for the heck of it. How heavy of oil should I use?????
    Adam
  2. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    You'll be sure to get alot of different opinions on here, which is the great thing about a forum.
    I use Amsoil 80W90 in both of my diff's. I also use gaskets, but some guys prefer rtv.
    Good luck. Sounds like your Saturday morning is planned out.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I use 80/90 and permatex black rtv.
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Good thats what I bought 80/90. How much oil will I need??? I have a little over a gallon of the stuff. I will be using a gasket with RTV (Even thou the gasket has a lifetime warrenty) hahahahahaha
    Adam
  5. bluehen
    Nov 11, 2004
    215
    DE
    I should have posted also about the $1.99 tap that screws right onto your bottle. AZ or PB has 'em. They come with a tube that's about 12" long. Cut it to whatever length makes pouring easier and stab the bottom of the bottle when your pouring to keep it flowing.
    Of course it depends on what diff's you have as to how much you'll need. With one gallon you might be a quart or so short if you're doing both.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I used 80/90 and no gasket just Ultra Blue RTV. My front 60 has 3 quarts and my 14FF has 5 quarts:D .
    Ira
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Go ahead and get another gallon. I used the gasket/rtv combo also and it worked great.
  8. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    The 80/90 and always just cleaned cover and RTV'd it.
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Gaskets always seem to leak for me so i just use rtv now.
  10. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    And most shops round here use rtv...
  11. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    hey this sort of off subject but, what about the axle seals for a rear 14bff? mine leak like heck and ive only pulled my axles 2 times each to clean my brakes. can i use rtv to seal it up? or should i get a new aluminum gasket or whatever it is.....? thanks a bunch
  12. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Go for it!! :waytogo: have a buddy that uses the stuff on everything. Including carb to manifold!! :doah: :haha:
  13. stevos67k20
    Sep 29, 2005
    140
    Somis
    sweet! thanks:)
  14. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    yup, that's all i ever use on the axles, thin coat of RTV and seals right up.
  15. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Make sure you buy some BrakeKleen and spray the heck out of the inside of the diff to clean out any gunk that has built up in there. Before you close it up and add the new oil, let the diff sit for awhile to make sure that all the BrakeKleen gets a chance to evaporate. FWIW, I usually use a can per diff.
    Oh, I use any brand of 80/90- usually I go for the one that's on sale. And RTV for the cover.
  16. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I work for CAT and have been using 80/90 and CAT flexible gasket sealer. It is blue rtv like stuff but I like it better and it is usually free. Leftovers from a job.
  17. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Ultra Flange II from Honda, it comes in a can like cheese whiz.
    Oh and PAD
  18. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I took my diff cover off and only about 2 drops of oil came out :doah: . But I didn't really drive my truck so I doubt I really hurt anything. If I did I guess I will find out and put a better axle in :D .
    Adam
