Rear end Question?
Discussion in 'The Garage' started by jackh, Dec 16, 2003.
  1. jackh
    jackh Registered Member
    Dec 7, 2003
    13
    I am running the stock 10 bolt rearend in my 86 K5 Blazer and was wondering how or what rearend I could go to that would better hold up to the 425hp/512 ftlb torque.
    Note ! This Blazer will never be used off road, it currently has 265-75-15 street tires on it. These tires do make alot of noise during a WOT start. But I cringe every time /forums/images/graemlins/confused.gif, thinking this is the time the rearend will give up.
    I am currently out of money for this project so I need to upgrade the rearend for as cheap as possible. Please HELP.
    Thanks,,,,,Jack
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thanks,,,,,Jack
    [/ QUOTE ] In my honest opinion, you can't get any better then a 14 bolt FF for a rear axle, and they're fairly cheap too. /forums/images/graemlins/thumb.gif Then use the 8 to 6 lug adaptors so you can keep the same rims. Just make sure the gears match the front.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Atleast put in a 12 bolt. I just built one the other day for a Chevelle with a 502, there pretty good rearends.
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] A car 12 bolt is a different rearend than the familiar truck 12 bolt. And I don't think a 12bolt is enough anyway. If you keep that tire size I would look for a 14BSF or FF.
  5. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i dunno whats the purpose of having such a nice engine in a stock rig thatll never see the Dirt,unless your interested in Drag racin... If thats the case, Then think about putting a ford 9 inch in there, if you dont care about using a ford part. Less weight then the 14ff. Plus its Fairly strong.
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I second the ford 9" but I would prefer a 14BSF with 6 lug axles. It would be bolt in for the most part and be plenty strong.
  7. jackh
    Dec 7, 2003
    13
    What's a 14BSF or FF? /forums/images/graemlins/confused.gif Are these rearends out of trucks, What kind? Can I find one at a junk yard? I'ed like to stay with the 6 lug without needing an adapter.
    Thanks,,,,Jack
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    GM made to different rearends that are called " 14b". The 14bolt Full floater (the big one) is a 10.5" ring gear rearend with full floating axles and hubs, only came in an 8 lug version. It was put in 3/4ton HD and 1 ton pickups, vans, and 3/4HD suburbans. With this axle you get your pie and eat it too because it is one of the best HD rearends that is great for offroad use and to top it off they are plentifull and cheap! It will handle up to 44" tires with some serious HP no problem./forums/images/graemlins/thumb.gif
    The second one is the 14bolt semi floater or "metric" 14B, it's the "small one". It wasn't made until the 80's but is a decent rearend for medium duty applications. It has a smaller 9.5" ring gear than it's big brother and came in both 6&8 lug versions. It comes from 3/4ton light duty and 1/2ton HD applications. This is a great upgrade from the weak 10 bolt that will handle some good HP along with oversized tires up to around 37" to 38". One to look for is a 90's 3/4ton light duty 6 lug 2wd truck.
    Both are great rearends that will last a long time and handle some serious abuse. I have a 14BFF and can attest along with many other guys that it is a bullet proof rearend. /forums/images/graemlins/smile.gif
  9. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I am aware of that. But I didnt think it is any weaker.
  10. jackh
    Dec 7, 2003
    13
    Thanks for the info. Will start looking tomorrow. /forums/images/graemlins/smile.gif
    Later,,,,Jack
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im not sure but, i dont think that the 14bsf came with 6 lug until 88. im also no sure on the width on the 88 and newer axles or the spring pad width. i do know that you can get aftermarket 6 lub axles for about 100 each to fit the older 14bsf
  12. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You are correct.
    2wd 88 and later trucks have the same width as the older axles but the spring perches must be moved. The 4wd rearends are wider but I have heard that the later model 4wd rears are the same width as the front earlier strait axles, this would be nice for correcting the narrower rear trac width that our trucks have.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I like the FF becouse there is no "C" clip. If you do break a axle shaft, you can still drive it home, as where the SF your tire will be laying on the grounds and so will that corner of your truck. /forums/images/graemlins/frown.gif
  14. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Just an FYI....as strange as it may seem, the car 12B is stronger than the truck 12B. The car's pinion stem diameter is 1-5/8" whereas the truck's is 1-7/16". The carriers are a little beefier on the car's too. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  15. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    yep
  16. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thank You, got it now!!
  17. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    The 6 lug is also fairly common in the Z71s. Not all of them got the 14 blt. I have noticed that most of them that did have it were pre 95, although I have seen a few later ones.
  18. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I run a 14 bolt Semifloater in the rear. I have broken it before, no it wasnt any thing internal in the diff. I broke the housing actually, I think I would have broken a FF rear end too because they both have the same tube thickness and diameter and I crushed both rear axle tubes. I love the rear end though, has more clearance than the FF and its just as strong for my app and it doesnt weigh 10,000 pounds either.
  19. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    also ive noticed that at least the 95-up 10 bolts have two sets of leaf pads welded to the tubes,
    i dont know why though.
    i know for 95 4x4 shorty and for 98 Z71 at least, with 8.5" rear. was this started for 88-up ? or ?
    and yep car 12 bolt were made with a bit thicker parts,
    12 bolt truck seem to be weakest of all gm axles and most or all dana too. car 12 and truck 12 are two different worlds when it comes to parts interchangability, although you might be able to interchange diff cover bolts, maybe, haha
