?Rear End Ratio?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ditchdigger, Jan 7, 2002.
  1. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    Yo!
    I have an 84 K-5 Blazer, TH-700R4 trans
    I have the stock 10bolt with the
    optional factory locker.
    Does anybody know what my rear end gearing is?
    by the way, I have no sticker and would rather not
    pull the diff cover off.
    84 Blazin Bowtie!
    If you spin and Oriental,
    Do they become Disoriented?
  2. Ditchdigger
    Mar 11, 2001
    96
    The Great Midwest
    Anybody?
    Whats your stock gearing?
    84 Blazin Bowtie!
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    jack the rear of the truck up both tires off the ground and turn the tire one compleat turn and count how many times your driveline makes a compleat turn ie turns 3 and 3/4 turns =3:73's 4 and 1/4 turns 4:10's you get the idea[​IMG]
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  4. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    how about an open diff?
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  5. dyeager535
    26,980
    Whats your engine? Don't feel like looking for that link to the Blazer brochures, but at least for a few years, (80's sometime) a 305 equipped truck could ONLY get 3.08's or 3.73's, that was it. A 350 could ONLY get 3.08's or 3.42's.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  6. Ditchdigger
    Mar 11, 2001
    96
    The Great Midwest
    Its originally 305cid,
    Was the TH-700R4 Standard??
    I'm thinking its 3.73s but I'll try Mudhogs idea!
    84 Blazin Bowtie!
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  8. dyeager535
    26,980
    Would be interesting to find out if factory trailering options on these trucks included the numerically higher gear ratio standard. 3 leaf front springs, 6 leaf rears and obviously a towing hitch would likely indicate the "towing package"
    Dorian
  9. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I had an '85 K5 with a 305 and 700R4 with a nice stock receiver hitch that had 3.07 or 3.08 gearing. A real pig with 35s.
    Stupid is as stupid does, I just try not to do anything stupid.
    <a target="_blank" href=http://community.webshots.com/user/70gmc>http://community.webshots.com/user/70gmc</a>
  10. dyeager535
    26,980
    Ok, in '84, gas trucks, manual transmission was standard. Diesel was the 4 speed auto (OD) ONLY.
    Nothing is listed for axle ratios, but I'd figure my previous post about 3.42's for 350's and 3.73's only available with 305's to be accurate.
    Those of you thinking 9:1 is the limit with 87 octane, the 305 in '84 was rated at 9.2:1, and thats with a "poor" combustion chamber, unlike the Vortecs.
    Dorian
  11. dyeager535
    26,980
    Well, there goes that theory. : ) Trailer hitch doesn't equal "better" gears apparently.
    Dorian
  12. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    My 85 had the trailering package. It is easy to tell (besides the sticker in the glove box) because of the wiring harness for electonic brake control above and beyond the typical trailer plug. Mine also had 3.73s with the 305. But, I don't hink that was part of the trailering package as it is listed as a seperate line item entry on the sticker. Mine also has the tranny cooler and oil cooler. Would the oil cooler also be an effect of the trailering packages?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  13. JJ85K5
    JJ85K5 Registered Member
    Jan 2, 2002
    21
    So Cal
    can you put 4.10's or say 4.88's in a stock 10 bolt rear end and front end w/o changing the pumpkin? i can't afford lockers yet but want to turn 35's or 37's.
    thanks
    JJ85K5
  14. dyeager535
    26,980
    I would assume it COULD be, but if anything, if thats a stock tranny cooler, THAT would be something I would think would certainly be part of a trailering package. Beginning to think GM didn't do much for a "trailering package" on these trucks, you had to piece it together yourself in a special order, or get lucky and find one on a lot that already had all that stuff.
    If I were GM at that time, a K5 trailering package would have been the 350 or diesel, engine and tranny cooler (if auto trans) 3 leaf front, 6 leaf rear springs, trailering hitch and wiring, 3.73's, and 31 gallon tank. Those are all sensible options if you plan to tow, but I'm sure there was no option that covered all of that.
    Dorian
  15. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
  16. k5'er
    k5'er Registered Member
    Nov 29, 2001
    92
    PA
    i thought that the 350 came with 3:08's?? i hope so, i just bought a whole ft and rear with 3:73's thinking it would be an improvement!!!
    Mud! Its cool!
  17. dyeager535
    26,980
    3.08's were standard, 3.42's (in your case) were optional. Pays to check this stuff out BEFORE buying parts : )
    Dorian
