rear end ?'s
Discussion in 'The Garage' started by Big_Red, Jun 26, 2002.
  1. Big_Red
    Big_Red Registered Member
    Jun 11, 2002
    10
    california
    rear end ?\'s
    I was wondering which rear end is stronger or better out of: a new dynatrac dana 60, a full floater 14 bolt, or a currie extreme duty ford 9"?
  2. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    Re: rear end ?\'s
    all these rears are strong as he!!.it's just the Currie 9" and the Dynatrac 60 are about $2500 more than a set up 14 bolt(gears,locker,etc.).and i'm guessing the 14 bolt is still the strongest between the three.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: rear end ?\'s
    <font color="green"> 14 bolt, it's probably the strongest, but also way way cheaper then any of the others. You could buy a roached one and rebuild it for probably $600, with a Detroit and your choice of gears, all new parts. The others would be thousands more. A 14 bolt is about the same strength as a stock D70, the ring gear is just slightly smaller. The only drawback is that it's bulky and has poor ground clearance, but it can be shaved to help out with that.</font color>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: rear end ?\'s
    14FF.
    I have never seen one fail. I have seen D60's, stock or not, fail.
    Ford 9"...forget it! /forums/images/icons/tongue.gif
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    Re: rear end ?\'s
    id go 14 bolt.just got mine from the junk yard this weekend.150 bucks and im one step closer to 3/4 ton all the way round.
  6. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    Re: rear end ?\'s
    id go 14 bolt.just got mine from the junk yard this weekend.150 bucks and im one step closer to 3/4 ton all the way round.hell yeah
