Rear end sag
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mikeperez22, Jun 19, 2004.
  1. mikeperez22
    mikeperez22 Registered Member
    May 11, 2004
    41
    I'd like to lift the entire Blazer about 2". The rear end seams a lot lower when you look at it from the side. I'd like to avoid using blocks if possible. Does anyone make a 3" spring kit for the rear. I could then use a 2" on the front. The other option is to use a 1" on the front. Anyone make that? Thanks.
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    The body line of the 1st gen's will fool your eye.
    The front wheel-wel is larger than the rear as well as the contour of the body slopes down.
    Are you sure the rear end is sagging?
    Put a level on the bed rail and see if it actually is or not.
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    probably your best bet is to go with a 4" lift rear and a 2" lift front spring, then add a 1" ORD Zero-Rate spring to the front to even it all out and make it look right.
    Here is the link to ORD...
    http://www.offroaddesign.com/catalog/Zero%20Rates.htm
    If you dont want that much lift, then you can put a 2" spring lift on the front and rear then add the 1" Zero-Rate to the rear and that will even it out (this is what I did, but will be swapping to the above lift as soon as $$ permits)
  4. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Ive got 4" TCI EZ rides up front, 6" TCI in rear plus a zero rate and my back end is still a little low. Like was mentioned use a level on the bed rail instead of only going by look but the bottom line is you want it to look right. I'd recommend going with whatever front spring you want first, after installation jack up the rear until its where you want it and measure how much lift you need, otherwise you are shooting in the dark as you wont know how much new springs will raise your truck above what it is now. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif
