Rear end sag?
Discussion in 'The Garage' started by nad, Mar 25, 2006.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    What's the best way to remedy slight rear end sagging with a 4" lift without making the rear stand higher than the front? I know there are probably several different ways, but I'd like to know the cheapest, easiest, and best working/looking. Thanks guys.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    ORD Zero rates
    or a set of add a leafs will bring it up but it will make the suspention stiffer.
    0 rates wont change your spring ratio.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Like Thunder says. But if you don't need that amount of lift you can just buy a piece of flat bar the right thickness, drill a hole through it and bolt it to the spring pack. (radius the ends like ORD do). ORD's ones are great if you want to relocate the axle though. You may well need longer through bolts. Many companies sell them (like Explorer ProComp) or if you have access to a lathe just get a good quality bolt long enough and turn the head down to a peg to fit your axle location hole (that's what do as they're so easily available over here).
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I added two more leaves from another spring pack, brought the rear up to level, and also firmed it up some to help with the "squishy" bouncy rear ride. :D
