rear end u joint strap?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Sep 21, 2001.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Do the 10 bolts and the 12 bolts use the same straps to hold the u joint in? I am building a 12 bolt for the Jimmy and wondering wht else I need. It didnt come with the straps. Also does it use the same u joint?
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    my 10 bolt straps worked on my 14 so im guessing they fit the 12.
    You know who I am
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I went out and stuck a spare U-joint on the 12 bolt and it appeared to fit perfectly - and the strap holes appear equal.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
