rear end went boom(need quick resoponse)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Dec 3, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    ........i popeed it into drive and it went boom, and then didn't move, so i called triple a, i was only within like 2 minutes walking distance from my house anyways. i pulled the diff cover and parts started to fall out, well that can't be good. luckily i was after i went to the trail and not while in the woods, so now i'm in search of a 14FF with 3.73 gears so when i run my 33's and so they'll match the ones up front, will it be ok to run 3.73 with 35's????????
    hola<P ID="edit"><FONT class="small">Edited by FatBoyBlazer on 12/04/01 11:20 AM.</FONT></P>
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Re: rear end went boom
    BOOM.
    My rear end does that all the time. Then the little woman tells me to get out of the house.
    There is another guy looking for 14FF 3.73s at the moment. I have a whole diff in Ca.
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got a 3.73 ring and pinion for a 14-bolt. Cheap! If ya need 'em... But for 35's I run 4.10's or 4.56's.
  4. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    would it be alright to run 4.10 on the rear and 3.73 just in the snow or on a slic road
    hola
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That would make it handle really strange. The front end would be trying to go faster than the rear end. [​IMG]
  6. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    there was some talk about burn outs, what would spin the 33's better 4.10 or 3.73
    hola
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    then your t-case might go boom to match the rear end...minute differences (4.09 4.11) are fine. when it gets into tenths it gets bad...or so i am told...
    -zakk
    '77 1-Ton K5
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    4.10's would make it easier to light 'em up. 3.73's would make 'em spin faster for a given engine speed. [​IMG]
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would just go ahead and get a 4.10 or 4.56 (if you have O/D). You might think about running 33's in front and 35's in the rear and only using 4wd if you get stuck. You would be less likely to mess up the xfer that way (it might look cool too[​IMG]).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    or you could do it right, same size tire and same ratio. 35's i would not go smaller than 4.10. i would personaly recomend 4.10 if you have a stick. for an auto i would go with 4.56.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  11. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    the only reason that i need 4wd for now is the winter(i live in new england), i think that i'm gonna get the 4.56 rear end because i've alreardy located one, it's for 250 bucks.is that a good price, it's also out of a c30 so would that still be OK?? then mabey in the spring i'll get a dana 60 if i can afford it
    hola
  12. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    ttt
    hola
