rear end with 3.73 or 4.10 needed in washington state.
Discussion in 'Parts & Trucks Wanted' started by zach78k5, Aug 1, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I need a rear end with 3.73 or 4.10 gears. I have a 14 bolt 8 lug with 4.10 to trade straight accross or I will pay cash.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have just the set of gears will that work?
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    How bout a 98 10 bolt 3.73?
  4. zach78k5
    May 14, 2000
    406
    that would work. I assume it is a 6 lug and would bolt right in to replace my 86 10 bolt correct? if so, how much.
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I think the spring perch and shock mount (post 87/91) would need to be moved to fit in your 86.
    Good Luck
  6. zach78k5
    May 14, 2000
    406
    Someone please
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    http://www.snort4x4.com/forum/showthread.php?s=&threadid=2524
    This guy has a SF 14 bolt for sale for $100, it is 8 lug though if you were looking for something that was 6. He has some other things for sale too, might have something you can use. He is in South Seattle BTW.
    And you should check out the SNORT 4X4 board that rear is listed on, its a local board with a lot of people in your area, you should post a wanted ad there /forums/images/graemlins/thumb.gif
  8. T-ROY
    T-ROY 1/2 ton status
    Dec 3, 2002
    468
    Orchards, Wa
    I have one in Vancouver. Are you looking for a front as well? Do you happen to have an 8 lug front (10 bolt or 44). I would trade front and rear straight across. I also have a truck that I just got that has a 12 bolt rear, let me make sure of the gear ratio and that might work as well.
    Please get back to me.
    T-roy
